Hi all,
I'm wondering what does the value inside {} mean in the value of the key "expression" in the json result of a trigger.get ?
Using Zabbix 6.0
Here an example:
"jsonrpc": "2.0",
"result": [
"triggerid": "634369",
"expression": "{652522}<-70",
"description": "RF Level low {HOSTNAME} Radio Port 1",
"url": "",
"status": "0",
The corresponding trigger 634369 has the following expression:
"avg(/R12-C21/genEquipRfuStatusRxLevel.268451969,10m)<-70", so I thought is sometihng related to hostid+key.
Searching the answer, I found some examples that state it's a functionid, but still cannot reach details on that, don't know which method can retrieve it
Waiting for hearing from You!
Regards
Alberto
Using Zabbix 6.0
Here an example:
"jsonrpc": "2.0",
"result": [
"url": "",
"status": "0",
Regards
Alberto
