Issue with Ez Texting
  • duke002
    • Dec 2016
    Hello, I am having an issue with Ez Texting and can't figure it out. When I originally setup Zabbix it was working fine then a couple of months ago it stopped working.
    I am currently running Zabbix version 3.0.3 on CentOS 7. In the action log it is saying that the username or password (for Ez Texting) is incorrect or the API is not enabled. I know the username and password is correct because I can log into Ez Texting just fine with it. I can see in Ez Texting that none of the alerts are coming over from Zabbix. My user has also been assigned text alerts under users and media. Am I missing something or is there an additional step I need to do to get this work?
    Thanks for any help you can give!
  • ctw195
    • Mar 2017
    I'm having the exact same problem
    I'm having the exact same problem; I'll let you know if I find a solution.
