v6.4.15 > v7.0.0: Media types > Used in actions
  • ltep
    • Nov 2022
    • 42
    After upgrading my Zabbix instance from v6.4.15 to v7.0.0 i noticed an issue with the assigned actions for all the media types.
    I have multiple Trigger actions configured in Alerts > Actions > Trigger actions.
    For example Trigger "action A" has an Operation set where it sends to user A and Send only to "Media Type A (HTML)".
    When i check Alerts > Media Types > Used in actions column > every media type that exists in Zabbix has "action A" assigned while i only used media type ""Media Type A (HTML)" in the operation of "action A".
    This seems to be incorrect. There is no way to remove it.
  • KaloyanHr
    • Apr 2024
    We have a similar issue after an upgrade from v6.4.7 to v7.0.0. On our prod zabbix server we see correct behavior, however on the v7.0.0 test zabbix server which uses the same configuration, all actions (regardless if it's a trigger, discovey, autoregistration, etc.) that have any operation like "Send message to users: user1 via all media" or "Notify all involved" makes the action appear under "Used in actions" for absolutely all Media types - even if they are disabled. When comparing to our prod server running v6.4.7 , there it is correct - only the relevant actions appear only for the enabled media types. To me, this also seems to be incorrect. Can you please advise ?
    Thank you
      Seems like some upgrade issue, you might want to register a ZBX ticket on "support. zabbix. com/ projects/ ZBX/ issues" (note the spaces, those are for avoiding post approval)
      • ltep
        • Nov 2022
        • 42
        Reported [ZBX-24670] Trigger actions assigned to all media types after upgrading to v7.0.0 LTS - ZABBIX SUPPORT
        • ltep
          • Nov 2022
          • 42
          It seems expected behavior. See ZBXNEXT-4165 for more details.
