Upgrade from 6.4 to 7.0 in kubernetes, fails
  • JaniL
    • Nov 2023
    Server and web-service works as expected but the web/frontend gets this error
    Executing supervisord
    2024-06-07 12:45:37,321 CRIT Supervisor is running as root. Privileges were not dropped because no user is specified in the config file. If you intend to run as root, you can set user=root in the config file to avoid this message.
    2024-06-07 12:45:37,321 INFO Included extra file "/etc/supervisor/conf.d/supervisord_zabbix.conf" during parsing
    2024-06-07 12:45:37,325 INFO RPC interface 'supervisor' initialized
    2024-06-07 12:45:37,325 INFO supervisord started with pid 1
    2024-06-07 12:45:38,329 INFO spawned: 'nginx' with pid 17
    2024-06-07 12:45:38,331 INFO spawned: 'php-fpm8.3' with pid 18
    [07-Jun-2024 12:45:38] ERROR: [pool zabbix] cannot get uid for user 'nginx': Success (0)
    [07-Jun-2024 12:45:38] ERROR: FPM initialization failed
    2024-06-07 12:45:38,365 WARN exited: php-fpm8.3 (exit status 78; not expected)
    2024-06-07 12:45:39,368 INFO spawned: 'php-fpm8.3' with pid 24
    [07-Jun-2024 12:45:39] ERROR: [pool zabbix] cannot get uid for user 'nginx': Success (0)
    [07-Jun-2024 12:45:39] ERROR: FPM initialization failed
    2024-06-07 12:45:39,399 WARN exited: php-fpm8.3 (exit status 78; not expected)
    2024-06-07 12:45:40,400 INFO success: nginx entered RUNNING state, process has stayed up for > than 2 seconds (startsecs)
    2024-06-07 12:45:41,403 INFO spawned: 'php-fpm8.3' with pid 25
    [07-Jun-2024 12:45:41] ERROR: [pool zabbix] cannot get uid for user 'nginx': Success (0)
    [07-Jun-2024 12:45:41] ERROR: FPM initialization failed
    2024-06-07 12:45:41,435 WARN exited: php-fpm8.3 (exit status 78; not expected)
    2024-06-07 12:45:44,440 INFO spawned: 'php-fpm8.3' with pid 26
    [07-Jun-2024 12:45:44] ERROR: [pool zabbix] cannot get uid for user 'nginx': Success (0)
    [07-Jun-2024 12:45:44] ERROR: FPM initialization failed
    2024-06-07 12:45:44,472 WARN exited: php-fpm8.3 (exit status 78; not expected)
    2024-06-07 12:45:44,472 WARN exited: php-fpm8.3 (exit status 78; not expected)ODE]
    Any good tips?
