I am new to this, so please bear with me.
I setup Zabbix 3.0 xxl server under CentOS 7, and it seems to work fine.
Then I setup the Zabbix 3.0 agent xxl limited under Debian 8, and it also seems to be fine.
(I used the docker images from here:
https://hub.docker.com/r/monitoringa...t-xxl-limited/)
I am able to setup my host (KVM VPS) to connect to the server, and it shows Enabled and green ZBX.
Now the issue is when I try to add items.
agent.ping works, but the few other ones I have tried I only get 'Unsupported item key' warnings on.
example:
vm.memory.size[available]
system.cpu.load[percpu,avg1]
system.boottime
-------- What I want to use it for --------
On the host I will be running a few docker containers.
This is the information I am after:
host: cpu load, used memory, free diskspace, disk io
for each docker container: cpu use, memory use, running status
Is this possible?
Do I have to use an agent other than the one I am trying with?
-------- TL;DR --------
What are the supported item keys for this agent? ( 3.0.4 XXL (2016-08-21) )
Can I get cpu, and memory information for each running docker container?
example:
system.boottime
Is this possible?
