Zabbix Agent 2 behind TLS interception
  • abockhold
    • Apr 2024
    • 14
    I've got a host (Debian 12) which is situated behind a firewall which does TLS interception. General TLS traffic works after adding the root CA to the system store. The Zabbix Agent 2 continues to fail. systemctl status zabbix-agent2.service shows:
    [101] cannot connect to [zabbix.example.com:10051]: C0F6FFAB597F0000:error:0A000410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure:../ssl/record/rec_layer_s3.c:1586:SSL alert
    How can I add the root CA to the certificate trust store of Zabbix Agent 2? Thanks!
    Regards
    Andreas
    • 5002
    By using all the provided TLS* config vars here.. https://www.zabbix.com/documentation.../zabbix_agentd
    • abockhold
      • Apr 2024
      • 14
      Thank you - unfortunately I didn't see your answer earlier. Probably I should try "TLSCAFile".
      • abockhold
        • Apr 2024
        • 14
        As a follow up: actually it did not work with adjusting TLS-settings. We had to disable TLS intercept for the agent traffic.
