How to create manualy closeable triggers
  • matzefratze81
    • Jan 2024
    • 10
    Hi all,
    we upgraded from Zabbix 6.4 to 7.0. I think in the old version it was possible to close the space is low trigger and it doesn't reopen. I learned that it works as designed, but is there any way to modify this trigger that a manaly close don't reopen it?
    min(/Windows by Zabbix agent/vfs.fs.dependent.size[{#FSNAME},pused],5m)>{$VFS.FS.PUSED.MAX.WARN:"{#FSLABEL}({#FSNAME} )"}
    Thx very much
    Matthias
    • 4996
    I'm pretty sure that trigger will reopen, if nothing is done to reduce disk space usage... It is just simple math...
    But newer versions have "suppress until" option there. Maybe that was the one you used?
