Zabbix-proxy pod is crashing while installing Zabbix on AWS EKS
  • gmarri
    • Jun 2024
    Followed below link for installing Zabbix on AWS Elastic Kubernetes Service (EKS)
    https://git.zabbix.com/projects/ZT/r...heads%2Fmaster
    However, after installation "zabbix-proxy" pod is crashing. Below is the error log.
    846:20240611:133038.628 Starting Zabbix Proxy (active) [zabbix-proxy]. Zabbix 7.2.0alpha1 (revision aab032e).
    846:20240611:133038.628 **** Enabled features ****
    846:20240611:133038.628 SNMP monitoring: YES
    846:20240611:133038.628 IPMI monitoring: YES
    846:20240611:133038.629 Web monitoring: YES
    846:20240611:133038.629 VMware monitoring: YES
    846:20240611:133038.629 ODBC: YES
    846:20240611:133038.629 SSH support: YES
    846:20240611:133038.629 IPv6 support: YES
    846:20240611:133038.629 TLS support: YES
    846:20240611:133038.629 **************************
    846:20240611:133038.629 using configuration file: /etc/zabbix/zabbix_proxy.conf
    846:20240611:133038.630 [Z3005] query failed: [0] no such table: users [select userid from users limit 1]
    846:20240611:133038.630 cannot use database "/var/lib/zabbix/db_data/zabbix-proxy.sqlite": database is not a Zabbix database
    Any ideas ?
    Thank you in advance!
    • 5004
    Zabbix 7.2.0alpha1 ???
    What an interesting version...
    But you can try to remove that DB file. With sqlite3 proxy should recreate DB and all of its schema during startup. Then it should not complain about missing tables and not being able to use it...
    • BalaC
      • Sep 2021
      • 22
      Same issue for me, its new installation and the directory is empty(/var/lib/zabbix/db_data/). Anyone already fixed it?
      • Markku
        • Sep 2018
        • 1788
        See Zabbix support portal: ZBX-24682 (shortlink, "sqlite3 for proxy partial broken in recent 6.4.16")
        However, it says that it's fixed in current master branch. So, do you still have to problem if you checkout the latest master?
        Markku
