Filters for Dynamic rules broken in V7?
  • AlanNZ
    • May 2023
    • 9
    We are working with the Windows by Zabbix agent active template. In particular the "Services Discovery"
    As it is configured, from standard the filters are set to not trigger if the service is withing the Regx macro {$SERVICE.NAME.NOT_MATCHES}.
    But it does not work. I have added the Google updater service to the macro and it still seems to cause a problem to be logged. I have testes the RegX in a tester and it seems to detect the event fine, but still the problem gets logged.
    I have also tried restarting the Zabbix Cache service to no avail.
    Any ideas what I could be doing wrong here?
    Alan Scott
  • Markku
    • Sep 2018
    • 1786
    Just to verify: Are you aware that usually the LLD rules don't remove not-discovered-anymore items immediately but after 30 days or so? Have you checked the discovered items if they have the warning sign about being deleted later?
    If that is the problem, you can delete the extra items manually.
    Markku
    • AlanNZ
      AlanNZ commented
      I have tried restarting both the client agent and the Zabbix proxy service, which I understand is supposed to speed up the changes, but the error still returns.
      Checking the {$SERVICE.NAME.NOT_MATCHES} in a RegX tester, it dose see to find a match on the services I'm trying to silence, but still, the problems keep coming. See below.
      ^(?:RemoteRegistry|MMCSS|gupdate|SysmonLog|clr_opt imization_v.+|sppsvc|gpsvc|Pml Driver HPZ12|Net Driver HPZ12|MapsBroker|IntelAudioService|Intel\(R\) TPM Provisioning Service|dbupdate|DoSvc|CDPUserSvc_.+|Microsoft Edge Update Service.+|GoogleUpdate.+|Windows Image Acquisition.+|PrintToLEAP.+|Management Wireless Application Protocol.+|WpnUserService_.+|OneSyncSvc_.+|GameInp ut.+|WbioSrvc|BITS|tiledatamodelsvc|GISvc|ShellHWD etection|TrustedInstaller|TabletInputService|CDPSv c|wuauserv|cbdhsvc_.+)$
      I appreciate your help.
  • Markku
    • Sep 2018
    • 1786
    Did you read my message above?
    Markku
