Adding ALLOWDENYKEY="AllowKey=system.run[*]" breaks my Ansible playbook MSI installer
  • bartman10
    • Aug 2022
    Hello, I'm kind of new to Zabbix and was asked to add ALLOWDENYKEY="AllowKey=system.run[*]" to our Ansible playbook that installs Zabbix 6 Client for Windows. When I add this as an MSI switch the installer hangs.
    Here is a copy of the playbook. If I take out the ALLOWDENYKEY= line the installer work.
    What am I doing wrong?
  • bartman10
    • Aug 2022
    I got it working locally with msiexec and have the proper syntax for the key
    ALLOWDENYKEY="AllowKey=system.run[*];DenyKey=*"
    This works locally with a MSI install but still fails when used in a playbook.
    • Markku
      • Sep 2018
      • 1784
      If the MSI app needs the double quotes in the string, maybe you have to escape them in yaml?
      Markku
