Get Resolved Problems via API
  • amedina
    • Apr 2023
    Hi all,
    I want to get all problems created and resolved from a period of time, for examples, all problems resolved last month. How can I get all resolved problems using the API?
    I think maybe using problem.get method and search for problems with a value in "r_eventid" different than zero, but I dont know how to make this search in the API. Is it possible? or there is other way?
    Thanks and best regards,
    Amedina
