ethernet in/out on FreeBSD
  • Jurz
    • Jan 2005
    • 11
    Anyone monitoring in/out data on ethernet on FreeBSD? Zabbix shows that monitoring this parameter is "not supported" any idea how do make it supported. I'm informed of an option to create my own script.
    Thanks in advance,
    -Jurz
  • jsimoes
    • 10
    If you use the Zabbix agent, you should use the following keys in the Items:
    netinem0 - traffic in
    netoutem0 - traffic out
    I hope it helps.
    Jose Simoes
