I wish to know about Template name with active or not.
  • CSYI
    • Apr 2024
    What is different the template name with between nothing and active?
    Basically, I want to set the agent type to active, but I don't know if I can use active for the agent type without using the active template.
    for example,
    windows_agent
    windows_agent_active
  • Answer selected by CSYI at 16-08-2024, 03:50.
    cyber
    Template name refers to used item types. So it would be easier to choose for you. If you have active agents , then most probably you also want to use active items. You can still use passive items with active agent.. You cannot use active items with completely passive agent (ServerActive is not defined in agent config)
