trying to read a log file for specific text "not supported"
  • TomCooper
    • May 2024
    Zabbix 6.4.16, running the zabbix agent on the zabbix server - Ubuntu 22.04
    I have a syslog process picking up log data from my switch and I want to have the Zabbix server notice when the word WAN appears in the log file and then generate a notification of a state change on that interface.
    I have tried to create an item for the log item, and a trigger using that item, but I keep getting errors.
    I must be doing something dumb. Help, please?
    Click image for larger version  Name:	Screenshot 2024-06-24 at 5.04.28 PM.png Views:	0 Size:	258.3 KB ID:	486295
    • 5002
    First go to item list and check why your item is in "not supported" state... I 'm pretty sure it will tell you something about permissions...
