IT Services
  • Lovespider
    • Sep 2004
    • 99
    IT Services
    I surfed the site looking for a solution but seems that the problem is still open.
    I confg an ITEM to Ping a host to monitor my ADLS link. Then I make a trigger that goes TRUE when the last ping is <>1.
    In "IT services" I try to connect this trigger to make a SLA but the bar is always 100% and the graph shows all bars green.
    If I show the trigger I can see that it is going TRUE and FALSE normally but the SLA graph is not following this behaviour.
    Do you have the same problem?
    Any solution?
    Thanks!!
    P.S. my Zabbix is 1.1.4
  • rochak
    • Jun 2007
    I have the same problem.
    Any solution?
