SNMP Template for FreeNAS 9.2.1.9
  • Ales Ulrych
    • Dec 2016
    • 36
    Hello everyone,
    Please for further advice. I am trying to monitor FreeNAS via SNMP.
    From the folder "/usr/share/SNMP/mibs and /usr/local/share/SNMP/mibs" MIBs he copied the files to Zabbix and work.
    Here "https://share.zabbix.com/index.php?option=com_mtree&task=att_download&link_ id=298&cf_id=39" I pulled Template, imported into Zabbix, but I can not assign it to FreeNAS. Error see Annex
    Cannot update host
    Details
    Created: Application "Disk partitions" on "FreeNAS".
    Created: Application "General" on "FreeNAS".
    Created: Application "Interfaces" on "FreeNAS".
    Created: Application "Memory" on "FreeNAS".
    Created: Application "Processors" on "FreeNAS".
    Created: Application "ZFS statistics" on "FreeNAS".
    Cannot find host interface on "freenas.interflag.local" for item key "hrMemDescr".
    Anybody know why? Where is the problem?
    Thanks so much for your help.
    Ales
  • Ales Ulrych
    • Dec 2016
    • 36
    I studied template and I found that on my FreeNAS file FREENAS-MIB.txt is not, which means that the Template or can not work. Does anyone know of any, that would be my FreeNAS 9.2.1.9 work ?
    • cronsloth
      • Oct 2017
      fixed it
      This link should help anyone still coming across this issue:
      The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
      you need to add an SNMP interface on the host that you are trying to link to the template. That fixed this error for me.
