SNMP Template with variable OIDs for Host Dashboard display
  • Beno
    • Jun 2024
    I would like to create a template using a partial SNMP OID only to be completed at the host level. The OIDs are presented as LEAFs that can change depending on where a card is installed in a router. Is there a way to create a template for that? I need to do this to create a host-based Dashboard on Zabbix 6.2. If there is a way to create a host dashboard with widgets, I would appreciate guidance as well. Thank you!
