Problem with Powershell script and zabbix_get/zabix_sender information
  • Beki4
    • Jun 2024
    • 10
    Hello , I have prepared a PS1 script that sends information to zabbix (zabbix_trapper) but I faced the following issue.
    When I ran the script on the local Windows host I got this ("test" is the machine hostname):
    But when I ran Zabbix_get command from the Zabbix server I got this:
    zabbix_sender [2824]: Warning: incorrect answer from "10.100.100.20:10050": [{"version":"7.0.0","error":"unknown request "sender data""}]
    Do you know why Zabbix server does not display the machine hostname and how I can fix the problem?
  • Answer selected by Beki4 at 27-06-2024, 17:26.
    Brambo
    • Jul 2023
    • 256
    There are multiple ways to use powershell to send data:
    1: send your data as a file
    .\zabbix_sender.exe -v -z <server-ip> -p 10051 -i test.txt
    In test.txt (can be multiple line if you want to send data to multiple host / items
    "your host name" item-key data
    2: directly, $date is for correct timestamp of the current time of that system,
    $argu is argument list: Zserver is zabbix ip, Zport is port number, key is the itemkey.
    the startproces global:Zsenderpath is the full path to my zabbix sender.exe
        $date = Get-date -Date $data -UFormat %s
        $argu = "-z $Zserver -p $Zport -s $Zhost -k $key -o $date"
        start-process -NoNewWindow -FilePath $global:Zsenderpath -ArgumentList $argu -Wait
    • Brambo
      • Jul 2023
      • 256
