How to add http response status code from trigger to tag
  • dremlin
    • Jul 2024
    I created web page monitoring, and trigger which checks the status code
    How to add http response status codes automatically to tag?
  • sergio.e
    • Jun 2024
    I have a similar need. What I need is to send the status code (web scenario) in the message ("media/webhook").
      {ITEM.VALUE} or {ITEM.LASTVALUE} duh...
      And to topic starter... if your recovery expression is exactly opposite to your trigger expression, you do not actually need it... If your status code will be =200 (like "not <>200"), then your trigger expression becomes false anyway and no need to define any recovery expression.
