net.udp.listen
  • snaki4
    • Dec 2016
    net.udp.listen
    Good morning,
    I'm trying to monitor some udp ports with net.udp.listen and I'm getting strange error
    Zabbix 3.2 installed from zabbix repo (ubuntu 16.04)
    zabbix-server# zabbix_get -s X.X.X.X -p 10050 -k net.udp.listen[5060]
    1
    web reports (and zabbix_server.log) that this key is unsupported : "Unsupported item key"
    zabbix-server# dpkg --list | grep zabb
    ii zabbix-agent 1:3.2.2-1+xenial amd64 Zabbix network monitoring solution - agent
    ii zabbix-frontend-php 1:3.2.2-1+xenial all Zabbix network monitoring solution - PHP front-end
    ii zabbix-get 1:3.2.2-1+xenial amd64 Zabbix network monitoring solution - get
    ii zabbix-release 3.2-1+xenial all Zabbix official repository configuration
    ii zabbix-server-mysql 1:3.2.2-1+xenial amd64 Zabbix network monitoring solution - server (MySQL)
    zabbix-client# dpkg --list | grep zabb
    Can somebody help?
    Thank you!
  • snaki4
    • Dec 2016
    anything? anyone know solution?
    • diggerzz
      • Aug 2015
      • 9
      I would like to know a cause of this issue too.
      I ran into the similar problem on Zabbix 3.2.1/CentOS 7+agent 3.2.1/Windows2012 recently.
      • snaki4
        • Dec 2016
        Solution were easy for me, I did use "Simple check" (because of clone ).
        It starts to work when I changed probe type to "Zabbix agent"
        • diggerzz
          • Aug 2015
          • 9
          I tried using "Zabbix agent" and "Zabbix agent (active)".
          An item got "Unsupported item key" state anyway.
          I'm going to try deteting and recreating the item tomorrow.
          • diggerzz
            • Aug 2015
            • 9
            I've removed the item from a template and created it directly on a host.
            Nothing changed.
            rpm -qa | grep zabbix
            zabbix-web-pgsql-3.2.1-1.el7.noarch
            zabbix-get-3.2.3-1.el7.x86_64
            zabbix-web-3.2.1-1.el7.noarch
            zabbix-server-pgsql-3.2.1-1.el7.x86_64
            zabbix-agent-3.2.3-1.el7.x86_64
            zabbix-sender-3.2.3-1.el7.x86_64
            zabbix-release-3.2-1.el7.noarch
            zabbix_get -s 192.168.101.111 -k system.uname - Windows SRVF01DC 6.2.9200 Microsoft Windows Server 2012 Standard x64
            zabbix_get -s 192.168.101.111 -k agent.version - 3.2.0
            zabbix_get -s 192.168.101.111 -k net.udp.listen[53] - ZBX_NOTSUPPORTED: Unsupported item key
            However, if I create net.udp.listen item on my zabbix server host, it works well:
            zabbix_get -s srvzbx -k net.udp.listen[53] - 0
            Does Zabbix agent support net.udp.listen key on windows hosts?
            • SBO
              • Sep 2015
              • 226
              net.udp.listen is working only on *nix systems for the moment
              Check the matrix : https://www.zabbix.com/documentation...ed_by_platform
              • diggerzz
                • Aug 2015
                • 9
                Thank you.
                I completely forgot about the useful table.
