dependencies issues during offline installation of zabbix-server 7.0 for RHEL8
  • mkda_pf
    • Jun 2024
    Hi dear community,
    I successfully installed zabbix-server previously into our development environment using recommendations from :
    https://www.zabbix.com/fr/download?zabbix=7.0&os_distribution=red_hat_enterp rise_linux&os_version=8&components=server_frontend _agent&db=pgsql&ws=apache
    and sources from:
    While installing onto another RHEL8 server in production, I am facing a dependency issue :
    #sudo dnf install -y zabbix-web-deps-7.0.0-release1.el8.noarch.rpm
    results in
     Problem: conflicting requests
      - nothing provides zabbix-web = 7.0.0-release1.el8 needed by zabbix-web-deps-7.0.0-release1.el8.noarch from @commandline
      - nothing provides zabbix-web-database = 7.0.0-release1.el8 needed by zabbix-web-deps-7.0.0-release1.el8.noarch from @commandline
    (despite zabbix-web-7.0.0-release1.el8.noarch being already installed, as seen below)
    #sudo dnf install -y zabbix-web-pgsql-7.0.0-release1.el8.noarch.rpm
    results in
     nothing provides zabbix-web-deps = 7.0.0-release1.el8 needed by zabbix-web-pgsql-7.0.0-release1.el8.noarch from @commandline
    I tried to install each package before the other, but it looks like dependencies are failing between these two packages.
    I searched for any older zabbix* package depiste this being the first attempt, and did not found any :
    #rpm -qa | grep -i zab
    zabbix-server-pgsql-7.0.0-release1.el8.x86_64
    zabbix-selinux-policy-7.0.0-release1.el8.x86_64
    zabbix-sql-scripts-7.0.0-release1.el8.noarch
    I tried to clean DNF cache and update :
    #sudo dnf clean all
    #sudo rm -r /var/cache/dnf/
    #sudo dnf upgrade
    But I am still having the same issue which prevents the installation. I ensured that I was not installing packages from another distribution as well, as read into similar topics.
    Does anyone knows what could be happening here by any chance ?
    PS : I can reproduce onto different servers in the same environment. The Linux version is the same between development and production :
    Linux ************  4.18.0-553.el8_10.x86_64 #1 SMP Fri May 10 15:19:13 EDT 2024 x86_64 x86_64 x86_64 GNU/Linux
    Many thanks in advance for your help - all.
    Have an excellent day.
  • Answer selected by mkda_pf at 03-07-2024, 10:10.
    tim.mooney
    • Dec 2012
    • 1436
    Rather than trying to install the packages one after the other, try installing them at the same time by listing both packages on the command line. yum/dnf and the rpm libraries they use have the notion of package transactions, and you want to list the packages you need in the same transaction.
    • mkda_pf
      mkda_pf commented
      Thanks a lot Tim, that was it, you are my day's savior.
      I'm impressed by the capacities of the tool, LLD and dependent items are the most powerful thing I have seen since a while.
      Cheers to the community.
  • tim.mooney
    • Dec 2012
    • 1436
    • mkda_pf
      mkda_pf commented
