I am using JBoss 7.1.1 final version. I configured Zabbix Java Gateway and tested some small java application it is work fine. I can see the Green colored status on Configuration> Hosts> Status tab.
I have added following options to JAVA_OPTS:
JAVA_OPTS="$JAVA_OPTS -Dcom.sun.management.jmxremote.port=4447 -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false -Djava.rmi.server.hostname=172.30.0.113"
After add above configuration wont start the JBoss server. It is gave below error message.
[root@jmx ~]# /jboss7/standalone/jboss.sh start
Found 172.30.0.113 IP Address
Starting server with ipaddress 172.30.0.113
JBOSS_CMD_START = /jboss7/bin/standalone.sh --server-config=mytest.xml
[root@jmx ~]# WARNING: Failed to load the specified log manager class org.jboss.logmanager.LogManager
Exception in thread "main" java.lang.ExceptionInInitializerError
at org.jboss.as.server.Main.main(Main.java:73)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native MethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.jboss.modules.Module.run(Module.java:260)
at org.jboss.modules.Main.main(Main.java:291)
Caused by: java.lang.IllegalStateException: The LogManager was not properly installed (you must set the "java.util.logging.manager" system property to "org.jboss.logmanager.LogManager")
at org.jboss.logmanager.Logger.getLogger(Logger.java: 60)
at org.jboss.logmanager.log4j.BridgeRepositorySelecto r.<clinit>(BridgeRepositorySelector.java:42)
... 7 more
Anyone have this issues?
Please help.
Thanks.
... 7 more
Please help.
Thanks.
