how to create UserParameter ?
  • bibi23
    • Oct 2005
    • 64
    I want to monitor disk IO with iostat. So, i should create UserParameter.
    But i don't find documentation on how to define UserParameter in zabbix_agentd.conf, nor how to create command script (what should be the return code etc..)
    I try to write a script like this :
    #!/bin/bash
    echo running >> /tmp/trace.log
    echo 1
    exit 0
    but the file /tmp/trace.log is not created, and after a long time, zabbix_server says that my UserParameter is unsupported.
    whta's wrong ?
    Thanks for your help
