Different values for history item
  • mihaidim
    • Jul 2024
    Hello!
    Is there any way to the history for an item, but only the different values for a period of time?
    For example I'd like to retrieve the last N different values of an item in the last 6 months, without getting all the history for that particular item and then do the post-processing. Can zabbix do this via API?
    Right now what I'm doing is to retrieve the host id (filter using host), then the item id (filter using hostid and key_) and then do history.get on that itemid that i just got. This method is very heavy computing expensive.
    What method do you suggest me to implement to be optimized and without fetching all the history in 6 months. Is there any smarter way?
    Thanks!
    Mihai
