In my compose file i have a zabbix-web section
If i uncomment those two volumes above, place my custom widget in the widgets directory and do a "Scan Directory" zabbix does find the widget but then all the other widgets are gone, I just see mine. To undo what I just did I have to comment those two volume mappings, scan the directory then enable all the original widgets that are found again.
How do I add a custom widget to a zabbix docker container implementation? I seem to be missing something.
Thanks,
Paul
HTML Code:
zabbix-web:
# https://hub.docker.com/r/zabbix/zabbix-web-nginx-pgsql
image: zabbix/zabbix-web-nginx-pgsql:${ZBX_IMAGE_TAG}
restart: always
network_mode: "host"
environment:
ZBX_SERVER_HOST: ${ZBX_SERVER_HOST}
DB_SERVER_HOST: ${DB_SERVER_HOST}
DB_SERVER_PORT: ${DB_SERVER_PORT}
POSTGRES_USER: ${ZABBIX_DB_USER}
POSTGRES_PASSWORD: ${ZABBIX_DB_PASSWORD}
POSTGRES_DB: ${ZABBIX_DB_NAME}
volumes:
- ./volumes/zabbix-web/etc/ssl/nginx:/etc/ssl/nginx:ro
- ./volumes/zabbix-web/etc/zabbix/web/certs:/etc/zabbix/web/certs:ro
# - ./volumes/zabbix-web/usr/share/zabbix/modules:/usr/share/zabbix/modules
# - ./volumes/zabbix-web/usr/share/zabbix/widgets:/usr/share/zabbix/widgets
Thanks,
Paul
