Zabbix Agent2 vs Agent
  • stevefxp
    • Aug 2020
    • 168
    Hello all,
    I have moved a majority of my agents over to Agent2 implementations, especially those with a DB on them. So far things have been pretty good but I am a little confused about the functionality within Agent2.
    For example when monitoring Linux I have the ability to pick the Agent template or the Active Agent template. Does Agent2 support both? It seems that when I pick the Active template I lose the green availability box for the passive side. Is this considered normal?
    Thanks,
    Steve
  • solution
    • Jun 2020
    • 272
    The manual has the answers you need.
    Active vs Passive:
    blog . zabbix . com/zabbix-agent-active-vs-passive/9207/
    Agent vs Agent2
    zabbix . com /documentation/current/en/manual/appendix/agent_comparison
    Agent2 Exclusive Items
    zabbix . com /documentation/current/en/manual/config/items/itemtypes/zabbix_agent/zabbix_agent2
    Green, Red, Gray - Availability icon
    "Since Zabbix 6.2 active checks also affect host availability..."
    zabbix . com /documentation/7.0/en/manual/web_interface/frontend_sections/monitoring/hosts
    **Additional spaces in links to avoid anti-spam
    Wellington
