How to Fetch and Save Resolved Zabbix Problems to CSV Using PowerShell?
  • eleaga30
    • Jul 2024
    Hello everyone,
    I'm trying to automate the process of fetching all resolved high and disaster problem events from Zabbix for the past month and saving them into a CSV file using PowerShell. I need the CSV to include the following columns: Time, Severity, Hostname, and Problem.
    I've written a PowerShell script to do this, but I'm encountering issues with it repeating events and not paginating correctly. Here is my current script:
    $token = 'tu_auth_token'
    $zabbix_url = 'http://tuservidorzabbix/zabbix/api_jsonrpc.php'
    $one_month_ago = [Math]::Round((Get-Date).AddMonths(-1).ToUniversalTime().Subtract((Get-Date '1970-01-01').ToUniversalTime()).TotalSeconds)
    function Get-Events($token, $one_month_ago, $lastEventId) {
        $jsonRequest = @{
            jsonrpc = '2.0'
            method = 'event.get'
            params = @{
                output = @('eventid', 'name', 'severity', 'clock', 'hosts')
                selectHosts = @('host')
                source = 0
                value = 0  # Solo eventos resueltos
                time_from = $one_month_ago
                sortfield = 'eventid'
                sortorder = 'ASC'
                limit = 1000
            auth = $token
            id = 1
        if ($lastEventId) {
            $jsonRequest.params.filter = @{ 'eventid' = $lastEventId }
        $jsonRequest = $jsonRequest | ConvertTo-Json -Depth 100
        $response = Invoke-RestMethod -Uri $zabbix_url -Method Post -ContentType 'application/json' -Body $jsonRequest
        return $response.result
    $allEvents = @()
    $lastEventId = $null
    $limit = 1000
    do {
        Write-Output "Fetching events starting from event ID $lastEventId"
        $events = Get-Events -token $token -one_month_ago $one_month_ago -lastEventId $lastEventId
        $eventCount = $events.Count
        Write-Output "Fetched $eventCount events"
        if ($eventCount -gt 0) {
            $allEvents += $events
            $lastEventId = $events[-1].eventid
    } while ($eventCount -eq $limit)
    $csvFilePath = 'problemas.csv'
    $headers = "Time,Severity,Hostname,Problem"
    $headers | Out-File -FilePath $csvFilePath -Encoding UTF8
    function Convert-FromTimestamp {
        param ([int]$timestamp)
        return [timezone]::CurrentTimeZone.ToLocalTime(([datetime]'1970-01-01').AddSeconds($timestamp))
    function Get-HostName {
        param ([array]$hosts)
        if ($hosts -ne $null -and $hosts.Count -gt 0) {
            return $hosts[0].host
        } else {
            return ''
    foreach ($event in $allEvents) {
        $severity = switch ($event.severity) {
            3 { 'High' }
            4 { 'Disaster' }
            default { '' }
        if ($severity -ne '') {
            $time = Convert-FromTimestamp -timestamp $event.clock
            $hostname = Get-HostName -hosts $event.hosts
            $eventName = $event.name
            $line = "$($time),$($severity),$($hostname),$($eventName)"
            Add-Content -Path $csvFilePath -Value $line
            Write-Output "Processed event ID $($event.eventid)"
    Write-Output "All events have been processed and saved to $csvFilePath"
    Any help or suggestions on how to improve this script to avoid repeating events and ensure proper pagination would be greatly appreciated. Thank you!
