I started using Zabbix recently and I am setting up the Monitoring System for our internal systems and a web site.
What I did set up is to monitor if the web site is loading and if a simple Login works. So far so good.
Now I want to test a function on the website, for which a json web token is needed. I can generate the token and i can (if i have a token) test the function succesfully.
The problem is, the token only works for 24h until a new one is needed. To automate the process i thought i could create a token in the first step of the scenario and use that token in the second step to test the function.
My first step is a simple GET request, requesting for a token with the correct API Key, User ID and password (that works perfectly fine)
The second is a POST request with a small json code, which tests the function (wich also works fine with a token i manually generated from our system).
I want to put the body response of the first step, which is the token, into {$jwt} macro to use it inside the code of the next step.
Until now everything works fine but I somehow can't figure that one thing out.
Any help is greatly appreciated. Thank you.
