install zabbix 7.0 on RHEL 8.x fails - GPG checks FAILED - Wrong Public Keys?
  • jburysom
    • Jun 2024
    • 16
    Hello there,
    I’m trying to install zabbix 7.x on Red Hat Enterprise Linux 8.10 from the repository using the commands from the following docuementation:
    https://www.zabbix.com/download?zabbix=7.0&os_distribution=red_hat_enterp rise_linux&os_version=8&components=server_frontend _agent&db=mysql&ws=apache
    The installation fails with the following error dealing with incorrect gpg keys. Any help would be greatly appreciated. I tried installing by disabling the non-supported repository and it fails to find fping. Is fping needed in zabbix 7.x?
    Thanks!
    1. Errors from first attempt at installing:
    # dnf install zabbix-server-mysql zabbix-web-mysql zabbix-apache-conf zabbix-sql-scripts zabbix-selinux-policy zabbix-agent
    Zabbix Official Repository - x86_64 3.0 MB/s | 3.1 kB 00:00
    Importing GPG key 0xB5333005:
    Userid : "Zabbix LLC (Apr 2024) <[email protected]>"
    Fingerprint: 4C3D 6F2C C75F 5146 754F C374 D913 219A B533 3005
    Is this ok [y/N]: y
    Key imported successfully
    Zabbix Official Repository non-supported - x86_64 3.0 MB/s | 3.1 kB 00:00
    Importing GPG key 0x08EFA7DD:
    Userid : "Zabbix LLC (Jul 2022) <[email protected]>"
    Fingerprint: D9AA 84C2 B617 479C 6E4F CF4D 19F2 4753 08EF A7DD
    Is this ok [y/N]: y
    Import of key(s) didn't help, wrong key(s)?
    Public key for fping-5.1-1.el8.x86_64.rpm is not installed. Failing package is: fping-5.1-1.el8.x86_64
    GPG Keys are configured as: file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX-08EFA7DD
    The downloaded packages were saved in cache until the next successful transaction.
    You can remove cached packages by executing 'dnf clean packages'.
    Error: GPG check FAILED
    2. Subsequent tries fail with the following error:
    GPG key at file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX-08EFA7DD (0x08EFA7DD) is already installed
    The GPG keys listed for the "Zabbix Official Repository non-supported - x86_64" repository are already installed but they are not correct for this package.
    Check that the correct key URLs are configured for this repository.. Failing package is: fping-5.1-1.el8.x86_64
    3. Trying to disable the zabbix non-supported repository:
    # dnf install zabbix-server-mysql zabbix-web-mysql zabbix-apache-conf zabbix-sql-scripts zabbix-selinux-policy zabbix-agent --disablerepo=zabbix-non-supported
    Updating Subscription Management repositories.
    Red Hat CodeReady Linux Builder for RHEL 8 x86_64 (RPMs) 52 kB/s | 2.8 kB 00:00
    MySQL 8.0 Community Server 34 kB/s | 1.8 kB 00:00
    MySQL Tools Community 34 kB/s | 1.8 kB 00:00
    Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs) 54 kB/s | 2.8 kB 00:00
    MySQL Connectors Community 18 kB/s | 1.8 kB 00:00
    Red Hat Satellite Tools 6.9 for RHEL 8 x86_64 (RPMs) 22 kB/s | 2.1 kB 00:00
    Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs) 25 kB/s | 2.4 kB 00:00
    Error:
    Problem: conflicting requests
    - nothing provides fping needed by zabbix-server-mysql-7.0.0-release1.el8.x86_64 from zabbix
    (try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
  • tim.mooney
    • Dec 2012
    • 1437
    Any template or item that uses any of the icmpping variants relies on fping being available.
    In addition, there's an option in the GUI to ping a host, and I believe that uses fping too.
    There's an older version of fping available from EPEL. You could install that first and then do the Zabbix install you've attempted.
    I haven't tried Zabbix 7.x yet and I don't use the Zabbix package for fping (we package our own, since other software our network group uses also requires fping) so I don't know exactly what the problem is. It looks like the package is signed with the wong key, but I would have to spend some more time investigating to be sure.
    • elan
      • May 2025
      Facing this exact issue with zabbix 7.0- proxy
      Check that the correct key URLs are configured for this repository.. Failing package is: fping-5.1-1.el9.x86_64
      • elan
        • May 2025
        The fping package is created with older key. Import the older key https://repo.zabbix.com/RPM-GPG-KEY-ZABBIX-08EFA7DD using `rpm --import /etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX-08EFA7DD`
