Debian 12 - Agent 2 Installation
  • stevefxp
    • Aug 2020
    • 168
    Hello all,
    I have two Debian 12 servers that I am trying to add to Zabbix, using the Agent2 install. When I run the dpkg command I am seeing the following:
    dpkg: warning: files list file for package 'zabbix-agent2-plugin-postgresql' missing; assuming package has no files currently installed
    dpkg: warning: files list file for package 'zabbix-agent2-plugin-mssql' missing; assuming package has no files currently installed
    dpkg: warning: files list file for package 'zabbix-agent2-plugin-ember-plus' missing; assuming package has no files currently installed
    dpkg: warning: files list file for package 'zabbix-agent2-plugin-mongodb' missing; assuming package has no files currently installed
    Is this an error, as I do not see this on my Ubuntu servers, or can I skip this?
    Thanks,
    Steve
  • markfree
    • Apr 2019
    • 875
    You haven't mentioned your Zabbix version.
    After downloading, are you trying to install the Zabbix release package from the official repositories?
    dpkg -i zabbix-release_7.0-2+debian12_all.deb
    Or have you already done so?
    • stevefxp
      • Aug 2020
      • 168
      Yes I am downloading from the official repos. I am installing v7 agents across the board and Debian is v12.
      • markfree
        • Apr 2019
        • 875
        Did you remove the previous release package before installing the new one?
        This should list all of your repositories:
        $ sudo grep -Erh '^deb ' /etc/apt/sources.list*
        In my Debian 12 setup, the official release package added only these two active entries.
        deb [arch=all] https://repo.zabbix.com/zabbix-tools/debian-ubuntu bookworm main
        deb https://repo.zabbix.com/zabbix/7.0/raspbian bookworm main
        The packages quoted in the warning message refer to the Agent's plugins, but they do not exist in the repository.
        I think that an older version of the Agent used these plugins, but they are no longer needed.
        I guess that is just a warning.
