Formula Help
  • LukeAB93UK
    • Jun 2023
    • 72
    Formula Help
    So I have this formula "count(//icmpping[,,,,4000],7d,,"0")" which works wonders on a host, does exactly what I want it to do.
    Now I have another host where I put all my calculated items that apply to a group.
    I am trying to do this
    count(last_foreach(/*/icmpping[,,,,4000],7d,,"0"?[group="HOST GROUP HERE"]))
    But it is not working.
    This however does
    count(last_foreach(/*/icmpping[,,,,4000]?[group="HOST GROUP HERE"]))
    What I am trying to do is the total count across every host in my group that that item key has returned a value of 0 in 7 days instead of 1.
    Is there any way to do it I am a bit lost here.
  • markfree
    • Apr 2019
    • 875
    So, first you have a simple check item that returns an ICMP response.
    Then, I guess you have a calculated item that counts how many responses are 0.
    It wasn't clear to me if this formula of your is actually a calculated item, but I'm assuming it is.
    Why are you counting the ICMP item instead of the count item?
    Anyway... By using "count(last_foreach...)" you are only counting the last value of your ICMP items in your group, not the amount of the last 7 days.
    You could try "count_foreach".
    sum(count_foreach(/*/icmpping[,,,,4000]?[group="HOST GROUP HERE"],7d,"eq",0))
    • LukeAB93UK
      • Jun 2023
      • 72
      I am still getting my head around some of the formulas. I am just trying to count how many times that item key has returned 0 on all the hosts in my specified group in the last 7 days. The ICMP ping item checks once per minute so im essentially trying to get the outage minutes.
      I am currently doing it a diffrent way
      I have one aggregate calculation sum(last_foreach(/*/kpi.outage.time?[group="HOST GROUP"])) which adds up the value of that item which is this formula with the key "kpi.outage.time" = (count(//icmpping[,,,,4000],7d,,"0")) but I was wondering it it was possible to do it directly using the item key "icmpping[,,,,4000]" instead of having to have 2x calculated items basically. One to count it per host and then 1x to add all that up in a group which is what im doing now.
      I just tried the suggestion you provided but all I got was
      • Incorrect value for field "Formula": invalid number of parameters in function "count_foreach".
