problems with discovery rules (Zabbix 6.2.6)
  • genesis_182
    • Jul 2024
    I'm having trouble with discovery rules.
    I have an Aruba switch connected via snmpv3, but when the discovery rules run, I get an alert of the following:
    When you run the following command on the zabbix server, it works without any problems.
    snmpwalk -v3 -u zabbix -l authPriv -a SHA1 -A $Rtfds4gfgyuhb -x DES -X $Rtfds4gfgyuhb 172.40.41.236
    What am I doing wrong?
    Any help is welcome. thank you.
  • Markku
    • Sep 2018
    • 1784
    Does this help: https://www.zabbix.com/documentation...itemtypes/snmp
    If monitoring SNMPv3 devices, make sure that msgAuthoritativeEngineID (also known as snmpEngineID or "Engine ID") is never shared by two devices. According to RFC 2571 (section 3.1.1.1) it must be unique for each device.
    RFC3414 requires the SNMPv3 devices to persist their engineBoots. Some devices do not do that, which results in their SNMP messages being discarded as outdated after being restarted. In such situation, SNMP cache needs to be manually cleared on a server/proxy (by using -R snmp_cache_reload) or the server/proxy needs to be restarted.
    Markku
