Unsupported Item Key when using UserParameter on Scripts as Action Operation
  • RaulChiarella
    • Apr 2021
    • 59
    Hello, everyone.
    So...
    1. I created a UserParameter that restarts a Windows Service, like this:
    UserParameter=restartService[*], powershell -NoProfile -ExecutionPolicy Bypass Restart-Service -Name "$1" -Force
    2. I created that script so I could restart a stopped service on Administration -> Scripts like this:
    Scope: Action Operation
    Script: restartService[{EVENT.TAGS.Service}]
    3. Finally, I applied that action on a Trigger Action so when a specific service is offline, I would execute that command and restart the service.
    But, the problem is that when the trigger occurs, it tries to execute the action and it returns "Unsupported item key" on the remote command.
    What am I doing wrong? Am I forgetting something?
    I already restarted the Zabbix Agent and I created a item called Restart Service Test to see if I could restart SysMain using "reiniciaServico[SysMain]" and it worked...
    But when using that UserParameter on a Action Operation, it is giving me that Unsupported Key error.
    Any tips?
  • Answer selected by RaulChiarella at 24-07-2024, 20:16.
    Markku
    • Sep 2018
    • 1784
    Action script commands are not UserParameters (or other agent items). You need to enter the shell commands in the Commands field.
    Click image for larger version  Name:	image.png Views:	0 Size:	12.2 KB ID:	488167
    Consequently, you need to allow the system.run[] execution in the agent configuration, as the commands are run with system.run[] item.
    Markku
    • Markku
      • Sep 2018
      • 1784
      Markku
      • RaulChiarella
        • Apr 2021
        • 59
        Markku
        Thank you, it worked. I did'nt know that I could'nt use UserParameters on scripts! Thanks for the tip.
        The final AllowKey for `system.run[]` tho was: AllowKey=system.run[*powershell*Restart-Service*,*]
        So Zabbix Agent restarted the service successfully.
