Create a graph of data from a script that gets ran every minute
  • IntriguedGuest
    • Jul 2024
    Good afternoon, morning, or evening to y'all!!
    I am very, VERY, green when it comes to using Zabbix. I have been working with a company who uses it for monitoring & I want to get more used to it so I can help them further.
    One of the things I'd like to do is to take the information out of a csv that gets re-written from a PowerShell script that I have set to run every minute in Task Scheduler, and display that as a graph with multiple points.
    Example of the csv output :
    "Service", "MemoryUsageMB"
    "Example1","142.82"
    "Example10","2628.52"
    So on and so on. Services shouldn't get removed, only added
    Trying to look at different forums & different posts here, but its just hard to piece things together, and was wondering if anyone could push me in the right direction! I see how specific Zabbix could be if used by someone who knows there stuff, so I don't think this is impossible.
  • Markku
    • Sep 2018
    • 1781
    I'd consider using Zabbix trapper items:
    - create a host for this (or use an existing host)
    - in the host, create those Example1 ... Example10 items as Zabbix trapper items
    - in the PowerShell script, instead of writing the data in CSV file, use zabbix_sender to send the data to the items
    - in the host, create graphs from the items as you need.
    Instead of calling zabbix_sender you can also use some Zabbix sender PowerShell library (if exists) to do the same, or since Zabbix 7.0 you can also use Zabbix API (history.push) for it.
    Markku
    • IntriguedGuest
      IntriguedGuest commented
      Thought so. Will take a look at Zabbix trapper items and see how to actually utilize that! When you say use zabbix_sender instead of writing to a csv, are you talking about inside of my powershell script? I was under the impression that zabbix sender was only Python.
  • Markku
    • Sep 2018
    • 1781
    Other thing is that you could maybe also use Zabbix agent items, either via UserParameters or system.run[] items to gather the Example1..10 data as Zabbix agent (or Zabbix agent active) items, without the scheduled tasks on Windows.
    Markku
    • Markku
      • Sep 2018
      • 1781
      (Sorry for the delay, the forum does not show new comments very clearly)
      Yes, inside the script. See man page for zabbix_sender: https://www.zabbix.com/documentation.../zabbix_sender
      There is a Python library, but also something (non-official) for other languages as well, like https://www.powershellgallery.com/pa...ZabbixTrap.ps1 (don't know if it works). But you can obviously call zabbix_sender from the PowerShell script as well. I believe it is installed with the Zabbix agent on Windows.
      Markku
