Templator Tool
  • stevefxp
    • Aug 2020
    • 168
    Templator Tool
    Hello all,
    What is the Templator tool and should I be looking to use this when making some templates my own? If yes is there a install for Windows, as my PC is Windows based.
    Thanks,
    Steve
  • Markku
    • Sep 2018
    • 1784
    I believe the "Templator tool" is something that Zabbix (the company) uses internally to manage the mass of templates for various Zabbix versions. So it's nothing we need to care about, we can just create templates from scratch in the GUI.
    Markku
    • stevefxp
      • Aug 2020
      • 168
      I just thought maybe this would be a helpful thing to use when creating/modifying templates.
      • kkeith
        • Aug 2024
        https://gitlab.com/zabbix-tools/templator tells you a bit more about the tool...
