Hi, sorry if this has been covered before.
I am looking for suggestions on how to properly use the administration scripts to allow non sysadmin zabbix users to execute certain commands on different sets of hosts, for example restarting services, reboots etc.
i enabled remote command in the agent config, which works fine for restarting services and other commands ran directly on the agent server.
What i would like to know though, is it possible to have a script execute an ssh remote command from the server to run a script on our config manager server
i.e. ->
Type : Scripts
Execute on : Zabbix server
Commands : ssh zabbix@config-manager 'scriptXYZ.py --host={HOST.NAME} --command reboot'
what user are the commands run as on the server side? I assume the same as the zabbix server process i did not find the documentation.
Thanks.
D
i.e. ->
Type : Scripts
Thanks.
D
