* zabbix_server is not running
  • Aniket
    • Jan 2017
    I have restarted /etc/init.d/zabbix-server but it shows following error in zabbix-server.log
    tail -f zabbix_server.log
    5790:20170106:054702.451 === memory statistics for string pool ===
    5790:20170106:054702.451 free chunks of size >= 256 bytes: 2
    5790:20170106:054702.451 min chunk size: 6552 bytes
    5790:20170106:054702.451 max chunk size: 1101336 bytes
    5790:20170106:054702.451 memory of total size 1257920 bytes fragmented into 2051 chunks
    5790:20170106:054702.451 of those, 1107888 bytes are in 2 free chunks
    5790:20170106:054702.451 of those, 117232 bytes are in 2049 used chunks
    5790:20170106:054702.451 ================================
    5790:20170106:054702.451 End of DCsync_configuration()
    5790:20170106:054702.451 listener failed: zbx_tcp_listen() fatal error: unable to serve on any address [[-]:10051]
  • DmitryL
    • May 2016
    • 278
    Hello Aniket,
    Try running
    netstat -tulpan
    Maybe there is some zombie process of server still running on that port.
