Different paths in discovery rule?
  • WNDKK
    • Jan 2017
    Is it possible to create a Discovery rule that can go through a list of different macros/strings?
    I have a server with the agent installed where I have multiple files with the same name in different paths.
    The key would look like this:
    vfs.file.time[c:/Path/User1/file.doc,modify]
    So is there a solution to automatically change User1 to User2, User3, User4,... in this key?
    Thank you for your help.
