Remove specific host from specific trigger inside template
  • S771
    • Jul 2024
    I'm trying to figure out, how to remove few hosts from specific trigger defined inside template. I created one template that is automatically linked to any new Windows host that get registered in Zabbix. In this template I'm checking few different services, and one of the services is active on 230 out of 240 servers. Those 10 servers without said service are that way by design.
    But now Zabbix keep reminding me that this service is missing on 10 servers.
    Is there any way to exclude specific servers from just a single trigger inside template? I would still like to monitor all other services and items on those 10 hosts.
    I know I could just make duplicate template and remove that service, and then point those 10 servers to new template, but I'm sure there will be more exceptions in the future and that means a lot more templates.
    Any help is appreciated.
    For 10 servers you can just disable related items/triggers... takes a minute to do...
    • danielitm
      • Mar 2025
      • 28
      But when I update the template, the trigger is reactivated.
      • pyritejoe
        • Aug 2022
        • 15
        Funny I just answered something similar in a topic a couple of posts up from this. How I did it, but you can also Goto Data Collection -> Hosts > Click on a hosts triggers. If you have your stuff setup like I do with Host groups for Window/Linux ect you can select that host group and in the Name field put the trigger name. Once the comes up it will show you it for all the Windows host and you can just disable that trigger on them all from there.
