CPU monitoring in GHz
  • ozumu
    • Jul 2024
    Hello, I have a problem that I don't know how to solve. I want to monitor the CPU usage in GHz (as attached in the image), and I can't find what to put in the Key to show it to me.
    If anyone knows the corresponding key, it would be a great help.
  • Brambo
    • Jul 2023
    • 256
    not sure if the agent can do this by default (doesn't seem like it). But with a system run command, doing the following powershell command will give you the current speed in Mhz
    Get-WmiObject -Class Win32_Processor -Property CurrentClockSpeed | Select CurrentClockSpeed
    output is (in my current situation) which is actually the Base Speed of your screenshot.
    CurrentClockSpeed
    2000
    Optional if you want load per logical core:
    Get-CimInstance -Query "select Name, PercentProcessorTime from Win32_PerfFormattedData_PerfOS_Processor" | Select Name, PercentProcessorTime
    gives output like
    Name PercentProcessorTime
    0 23
    1 5
    2 40
    3 28
    4 23
    5 11
    6 0
    7 5
    _Total 17
    Total is sum of all divided by amount cores.
    With
    Get-CimInstance -Query "select Name, PercentProcessorTime from Win32_PerfFormattedData_PerfOS_Processor" | Select Name, PercentProcessorTime | ConvertTo-Json
    You get a json output which you then can use in LLD to auto populate your host
    • ozumu
      • Jul 2024
      Thanks for the reply, I'm checking within my infrastructure, and I'm sharing a screenshot of vSphere accessing the server (which is Windows) and seeing the performance, I would like to be able to bring the value that is shown in that graph.
      If you could help me out on how to do this, I would appreciate it.
      • Brambo
        • Jul 2023
        • 256
        Why do it the hard way then and not use the vmware: cpu usage item from the Vmware template.
        VMware hypervisor and VMware guest template both have this item.
        • ozumu
          • Jul 2024
          I'll try it with the template.
