Problems with Azure Cost Management Monthly
  • dalfieri
    • Feb 2024
    Hi Everyone,
    I'm having problems with Azure Cost Management by HTTP template:
    All monthly cost items only show the cost of the first day of the month and not of the total month.
    I tried both with Zabbix 6.4 and 7.0
    Has anyone had the same problem?
  • Luis Humelino
    • Aug 2024
    I may have found the problem.
    The monthly items that are erroneously showing the first day's of the month data have two pre-processing steps.
    The second one must have the function sum instead of first.
    Example:
    • leascherf
      • Jul 2024
      I fixed it this way.
      In the second json route preprocessing, I just kept PreTaxCost at the end.
      Add a new javascript preprocessing:
      var NewValue = value.replace(/[\[\]"]/g, '').split(',');
      var sum = 0;
      for (var i = 0; i < NewValue.length; i++) {
      if (NewValue[i] && !isNaN(NewValue[i])) {
      sum += parseFloat(NewValue[i]);
      return(sum);
      • leascherf
        • Jul 2024
        I added the image in a new comment because I cant edit the another comment.
        • rafael.roquete
          • Mar 2024
          Hello.
          I'm having the same problem and I was unsure about how pre-processing was configured on the item.
          leascherf, is it possible to send a print?
          I'm using Zabbix version 6.0.8.
          • rafael.roquete
            • Mar 2024
            I solved the problem by changing the value "first" to "sum" at the end of the JSONPath.
            $.monthCost.data.[?(@.BillingMonth == "{#AZURE.BILLING.MONTH}")].PreTaxCost.sum()
