How make alert when snmp don't answer?
  • gbiondi
    • Nov 2016
    • 75
    When snmp for any reason stop to answer, my Zabbix put a service 'snmp' in hosts turn to red, but no have alert triggered and if I dont check this I would found without data after some time..
    I have try this trigger on 'Template SNMP Generic':
    {Template SNMP Generic:sysUpTime.nodata(5m)}=1
    but many Windows host goes in alarm..
    You have a solution for this? I want alert if my snmp don't answer..
    All the best
    and good 2017
  • batchenr
    • Sep 2016
    • 440
    the way i can think of is to make on zabbix server machine a script that run
    #snmpwalk -v2c -cpublic $IPADDR
    and if the response of the script gets :
    Timeout: No Response
    you can make your own customized trigger..
