Monitor Website Response Times
  • stevefxp
    • Aug 2020
    • 168
    Hello all,
    I have created a dashboard to monitor my production websites, including response time and response code. What I would like to do is setup a color change when the response time goes above certain thresholds. What is the best way to pull this off. Is it another trigger?
    Thanks,
    Steve
  • moooola
    • Jul 2024
    • 33
    Setting up web monitoring on a host may meet your requirements.
    If you create a web scenario that has only one step, which is accessing the target URL of the target host, and execute it periodically, the response time will be recorded each time.
    If you set a trigger on the response time, you will be notified when the threshold is exceeded.
    • moooola
      • Jul 2024
      • 33
      Ah, you want to change the color. I may have said something a little off-topic. sorry.
      change color, change color . . .
      Is it like this?
      ​​Click image for larger version
