Veeam template not grabbing info on copy jobs
  • Tom_Davison
    • May 2024
    Has anyone seen this or managed to resolve this issue with the Veeam backup and replication template?
    All normal backup jobs are pulled through perfectly fine.
    Any of our backup copy jobs or our sure backup job do not seem to exist.
    I have manually logged into the Veeam interface with the account I am using to authenticate in Zabbix and it can see these jobs so I do not think it is a permissions issue.
    Kind regards,
  • ysus
    • Mar 2016
    • 102
    I believe this is a limitation of Veeam API - only "Backup" type is supported. Have the same problem and already asked Veeam developers for clarification.
    This reference lists paths (endpoints) of the Veeam Backup & Replication REST API and operations that you can perform by sending HTTP requests to the paths.
    • andreaf-it
      • Feb 2020
      • 36
      Kind regards,
      same issue for me,
      Best Regards
      • ysus
        • Mar 2016
        • 102
        Looks like this information is only available in Veeam Enterprise Manager API. At least "BackupCopy" type in mentioned in response body.
        Returns a resource representation of the job resource having the specified ID. Supported Platforms The request is supported for the following platforms: VMware vSphere VMware Cloud Director Microsoft Hyper-V...
        Fortunately Enterprise Manager does not require additional licenses and could be installed on the same machine as B&R server. I'm going to try this in test lab around mid-September.
