pgsql.custom.query return format
  • bmamo
    • Aug 2024
    Hi, I've searched all over the documentation but couldn't find anything regarding the format pgsql.custom.query returns its output.
    I'm doing a select count(*) on a table with the hopes of returning a numeric value, but the return is always being wrapped in a json format or similar.
    The value I am getting is : [{"count":2}]
    The value I need for graphing in this case would be just the output of the count, without the column header or formatting i.e.: 2
    Is this something that can be configured? I've tried doing \t in the sql file but it doesn't seem to be supported, returning an invalid character error.
  • Answer selected by bmamo at 06-08-2024, 17:03.
    Hamardaban
    • May 2019
    • 2714
    pgsql.custom.query[uri,<username>,<password>,queryName,<args...>]
    Return value: JSON object.
    Its normal! Just use JSONPath preprocessing for grab value.
    • bmamo
      • Aug 2024
      Just bumping this cause I'm still stuck on this. Anyone can help? Maybe a pointer to a documentation I could read?
      • Hamardaban
        • May 2019
        • 2714
        • bmamo
          • Aug 2024
          Exactly what I needed, an inspiration to get a result Thank you very much, now with $[0].count in preprocessor tab i can get the value. Perfect and thanks again!
