How to monitoring HPE Alletra MP (HPE Green Lake for Storage)
  • nhs192
    • Aug 2024
    Does anyone have the anyway to monitor HPE Alletra MP (HPE Green Lake for Storage) with SNMP ?
    Please give me the advice. Thanks
  • bboy8012
    • Oct 2020
    • 12
    I would start by getting the MIBs and converting it to a template reference https://sbcode.net/zabbix/mib-to-zabbix-template/
      That mib2zabbix.pl will not work ... its so outdated last updates to it from 7 years ago... https://github.com/zabbix-tools/mib2zabbix It was a good effort at a time, but template formats have been changed over time etc..
      • voyTech
        • Sep 2024
        I'm facing the same issue here - there are no templates for the Alletra and the conversion tool doesn't work with newer versions of Zabbix. I also couldn't find an MIB file to manually go through the OIDs and create a template by hand. Can anyone help?
          https://community.hpe.com/t5/hpe-pri...p/td-p/7221854
          • gelowe
            • Jun 2008
            • 30
            This of zero help, HPE is the Fing worst worst. They seem to only get more convoluted.
