Problem with snmp items
  • rogerp
    • Mar 2005
    Hi!
    Ive got a problem with snmp items. I can use snmpwalk and snmpget to get correct values from my routers on the commandline but when i add a item in zabbix it does not work. Im running zabbix 1.1a5 on fedora core 3 with net-snmp 5.2.1.
    This is a screendump of my item configugration:
    And this is the relevant part of the logfile:
    004392:20050309:133258 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.ho stid,h.status,i.value_type,h.network_errors,i.snmp _port,i.delta,i.prevorgvalue,i.lastclock,i.units,i .multiplier,i.snmpv3_securityname,i.snmpv3_securit ylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassph rase,i.formula from items i,hosts h where i.nextcheck<=1110371578 and i.status=0 and i.type not in (2) and (h.status=0 or (h.status=2 and h.disable_until<=1110371578)) and h.hostid=i.hostid and i.itemid%1=0 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by i.nextcheck
    004392:20050309:133258 In DBnum_rows
    004392:20050309:133258 Result of DBnum_rows [1]
    004392:20050309:133258 In get_value_SNMP()
    004392:20050309:133258 SNMP [[email protected]:161:0]
    004392:20050309:133258 OID [.1.3.6.1.2.1.2.2.1.10.1]
    004392:20050309:133258 In get_value_SNMP() 0.2
    004392:20050309:133258 In get_value_SNMP() 0.3
    004392:20050309:133258 Status send [1]
    004392:20050309:133258 In get_value_SNMP() 0.4
    004392:20050309:133258 In get_value_SNMP() 1
    004392:20050309:133258 Error [1]
    004392:20050309:133258 GOT VALUE [No sleeping]
    004392:20050309:133258 Getting value of [ifInOctets.1] from host [ROUTER_SEVEL] failed
    004392:20050309:133258 In zabbix_log()
    004392:20050309:133258 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.ho stid,h.status,i.value_type,h.network_errors,i.snmp _port,i.delta,i.prevorgvalue,i.lastclock,i.units,i .multiplier,i.snmpv3_securityname,i.snmpv3_securit ylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassph rase,i.formula from items i,hosts h where h.hostid=i.hostid and i.key_='zabbix[log]' and i.value_type=1
    004392:20050309:133258 No zabbix[log] to update.
    004392:20050309:133258 The value is not stored in database.
    I also get a full screen of:
    snmpget: Too long
    snmpget: Too long
    whenever i start the zabbix_server process, could it be some version problem with net-snmp or something?
    Anyone got any hints to what im doing wrong?
    Thanks!
    Roger
  • sinda
    • Apr 2005
    • 33
    hello,
    the problem of snmp hosts must be solved!
    any one can help me
    • sinda
      • Apr 2005
      • 33
      you have to verify that the net snmp is correctly installed.
