Monitor Windows services and display not running services
  • svc_zbx_6754
    • Aug 2024
    • 14
    Hi guys,
    is it possible to monitor Windows(server) services and check if they are running?
    I would also like to add a trigger if a service is not running and show the non-running services in a dashboard.
    Thanks alot in advance for your help and time.
    Kind regards
  • svc_zbx_6754
    • Aug 2024
    • 14
    Used LLD with service.discovery key. Item and Trigger prototype works.
    The problem with the dashboard still persists. Cannot find a widget that would make sense to display the services which supports item prototypes.
    • jhboricua
      • Dec 2021
      • 114
      Windows service discovery and monitoring is included in the default 'Windows by Zabbix Agent/Windows by Zabbix Agent Active' templates. Have you looked at those?
