Network discovery rule and actions
  • oxpy
    • Oct 2022
    Hi team,
    I've encountered an issue while using network discovery rules and corresponding actions for these network discovery rules.
    I want to add a common template "NetScan OS Generic Template" to all discovered hosts, as well as apply specific template "FIBERBLAZE test" to already discovered and created servers through actions that match certain checks.
    Initially, I created a network discovery rule with the following checks:
    • Zabbix agent "system.hostname"
    • Zabbix agent "system.hw.devices"
    • Zabbix agent "system.sw.packages"
    And the following actions:
    The rule highlighted in red is not working.​
    In template "FIBERBLAZE test", there are no matching items, triggers, graphs, etc., with template "NetScan OS Generic Template".
    Hosts are created correctly, and the first general template is applied correctly as well. However, when it comes to applying specific template "FIBERBLAZE test" to certain servers, nothing happens
    Then I decided to create different discovery rules and use each discovery rule for each action, but I also failed
    ​Is it possible in Zabbix to add a new template to hosts that have already been discovered and created using a discovery rule and actions? If so, I would appreciate some guidance on how to do this.
    Thanks in advance
  • oxpy
    • Oct 2022
    Please UP!
    Has anyone encountered something similar? I've tried different options, but I can't achieve the desired effect.
      • 5002
      All the above pics are broken in some reason... very hard to understand the question..
