Script type item get other item values
  • aleksander237
    • Apr 2022
    • 13
    Is it possible to use other item's values in a script item? Let's say that I would like to have an script item which uses bunch of other item's values, like (system.name, system.uptime, system.version) and create a script which uses them internally and give a result. My first attempt was to pass them as parameters:
    parameter name: systemName
    parameter value: last(//system.name)
    and use parameters in script. But this does not work.
    Any solutions?
    • 4985
    You cannot use other item values in any of item types... You can use some macros, like {HOST.NAME} for example (search for "Item key parameters" in https://www.zabbix.com/documentation...ed_by_location)
    • aleksander237
      • Apr 2022
      • 13
      Well, this is not entirely true. You can use other item values in the calculated items. So I Was thinking that you can do "the same" in the script by calling some methods from the global Zabbix JavaScript object. Something like this:
      var lastValue = Zabbix.avg("/Zabbix Server/zabbix[wcache,values]","10m");
      It would be usefull or at least possibility to pass selected values to the script via parameters.
      Thanks, anyway.
